use of Segmentizer Setup & Super schedule Operation
Hello All,
had a query regarding understanding about the functionality and application of "Segmentizer Setup"and Super Schedule Operation".
Do we have an application of this option in Process simulate Standalone..?
Please find attached snapshot of segmentizer setup.
Re: use of Segmentizer Setup & Super schedule Operation
This tool is not available on Robot Expert but is available on PS. You should be able to find it on GTAC : SegmentizerTool.
Hi GillesVelay,
Thanks for you fast reply.
Tried searching for SegmentizerTool in GTAC solution center but was not able to find related results or are you refering to a differnet location in GTAC to find solution. (am using PS Standalone 12.1)
Also please provide your valued inputs on Super schedule operation.
Apparently not yet available in 12.1.
In 12.0, it is there:
Super schedule is a Volvo concept. I suggest you check with Volvo.
Thanks a lot for your reply. Have downloaded and installed Segmentizer in PS standalone 12.0
Saw that Segmentizer is available for 12.1.1 but not for 12.1
This feature "segmentizer setup is showing up in PS search but not porvided for selection. Have loaded a study--- taken the path in Path editor--- still its not provided for selection.
Could you please let me know if any prerequisets are required to operate this. Any steps as to how to use this funtionality will be much helpful.
There is a manual automatically installed under eMPower\DotNetCommands\Segmentizer\Doc.
One more observation that was made is that, "Segmentizer" setup available in GTAC download site is applicable for 12.1 also.
I tried installing it and its working fine.
