where is the error
i need help with motionparameters.e file for fanuc
my robot fanuc lrmate_100i_rj3i_b
i have problems with upload
information from upload in process simulate
 location P11: ComputeManualRrsConfigString: wrong motionparameters.e file, number of joints with turns is 2, should be 3
motion_space             space_karel;
use_config               use;
interpolation_type       interpolate_by_2;
speeds_given             given;
joints_coordination      end_together;
cart_speed_to_jnt_cnvrt  by_lim_jnt;
speed_lim_jnt            2000.0;
default_control_parm     2000.0;
react_on_speed_excess    recalc;
check_joints_speed       check;
joint_limit_in_cart      stop;
is_wait                  wait;
approach_vec    approach_z;
cart_max_lin_speed       2000.0;
cart_basic_lin_speed     2000.0;
cart_max_lin_acc         4000.0;
cart_basic_lin_acc       4000.0;
cart_max_lin_dec         5000.0;
cart_basic_lin_dec       5000.0;
cart_max_rot_speed       2.2689275;
cart_basic_rot_speed     2.2689275;
cart_max_spin_speed      2.2689275;
cart_basic_spin_speed    2.2689275;
cart_max_roll_speed      3.665191;
cart_basic_roll_speed    3.665191;
zone_define  fine no_smooth ;
zone_define  coarse speed cartesian 3.0 ;
zone_define  medium speed cartesian 50.0 ;
zone_define  nodecel speed cartesian 99.5;
zone_define  sp_zone1 speed cartesian 30.0;
config_family               cf_over_head_pos;
joint_config_family j3      joint_cf_elbow_up;
joint_config_family j4      joint_cf_pos;
joint_config_family    j5        joint_cf_pos;
default_turns         j1 0 -180,    j4 0 -180,    j6 0 -180;
joint_vel_prof      rot     const_time_prof ;
Kind regards,
Benjamin Voelzke
7 REPLIES 7
Re: where is the error
Your motionparameters.e file should have this:
joint_config_family    j3      joint_cf_elbow_up ;
default_turns j1 0 -180.0, j4 0 -180.0, j6 0 -180.0;
after chaning i have the same error
Internal Error at file ABLEGEN.PE, operation ABLEGEN, location P1: ComputeManualRrsConfigString: wrong motionparameters.e file, number of joints with turns is 2, should be 3
use_config               use;
speeds_given             given;
is_wait                  wait;
Kind regards,
Benjamin Voelzke
you need to reopen the study and reupload the path
yes i'am starting ps again.
i make upload without rcs modul.
i think this is the problem.
Kind regards,
Benjamin Voelzke
If your motionparameters.e is correct, you should be able to upload without RCS module.
upload without RCS Modul is not possible.
i have the same error with all robot paths.
Smiley Sad
Kind regards,
Benjamin Voelzke
You are not changing the motionparameters.e that you think the system is reading. Or in you motion parameters, there is a still a turn definition with 2 joints only... I do not see any other reason.
With RCS, you can upload correctly even with a wrong motionparameters.e. Without RCS, the motionparameters.e should contain the lines I sent before for the definition of the config and turns.
