Do you mean
Reply
Solved! Go to solution
workpiece guidance
Hy!
Does anybody have expirience with workpiece guidance in Robotexpert?
I would like to create a path on a workpiece which is attached to the Robot. The Tool which  'follow' the path should be mountet on a fixed object in the room.
Is there any excample/posibility/approach how to do this?
Thanks for your help!
Philipp
Solution
Solution
Accepted by topic author PSchroth
‎08-26-2015 04:32 AM
Re: workpiece guidance
this is suported. U have to only check the Ext TCP option when creating new Conti Feature Operation.
D.
