Acceleration units keep changing in Test.Lab
In my channel setup I took acceleration data with mV/m/s2 as the sensitivity.  Whenever I display my data it is always in g's.  I can right click in the display and change my Y-axis unit to m/s2, but any new display always comes back as g's.
Is there any way to make LMS Test.Lab always display m/s2 by default rather than g's?
Re: Acceleration units keep changing in Test.Lab
Siemens Legend Siemens Legend
Siemens Legend
You'll need to launch the Unit Editor and manually set acceleration m/s^2 as the acceleration default unit.  Please screen shot below:
Make sure exit off all Test.Lab applications while making changing on unit editor.  Once you made the changes and saved, then launch Test.Lab.
Good Luck!
Hong
Thank you very much Hong. This worked.
Ciao
