Alternator vibration had every order, what could be wrong?
Analized two noisy claw pole alternators. There were basically even strength orders as shown in the plots. Are this typical? I had hard time relate those to any commen causes (unbalance, bent shaft, bearing frequencies, 5 windows on the case, 6 poles,  36th order elelctrical torque variations, ....).
Any one has seen those before and have some advice?
Thanks!
Re: Alternator vibration had every order, what could be wrong?
Attached is another plot.
