CAN bus sampling rate same as vibration sampling rate?
I am using LMS Test.Lab Signature.  I want my CAN bus channels to have the same sampling rate as my vibration channels.  Is there a way to do this?  CAN static sampling rates are 100, 200, 400, etc.
Re: CAN sampling rate same as vibration sampling rate?
Try changing the CAN bandwidth from 'Static' to 'Vibration' in the upper right corner of the Acquisition Setup worksheet:
Thanks, that worked!
