Calculating Damping
Looking for a deeper understating of difference between ratio, factor (Q) and loss. I am trying to confirm that if the below pictorial is how the LMS calculates damping. In addition how the three different damping values can be used in a practical application would be valued.
Re: Calculating Damping
Does this article help?: How to calculate damping from an FRF?
It has some examples of situations to watch out for, like influence of spectral resolution.  Damping terms are also explained.
