Can't get cursor menu in LMS Test.Lab
Hi All,
I am trying to right click on a display and get the cursor menu, with entries like  "Add Single Cursor, Add Double cursor, etc". This display has a lot of data in it.  Every time I right click, I get a "Curve menu" instead.
Any ideas?
Re: Can't get cursor menu in LMS Test.Lab
Siemens Legend Siemens Legend
Siemens Legend
Hello Fred,
If you CTRL-right click in the display you will always get the full menu.   With a display full of data it is often hard to find an open area to right click and get this menu.
Siemens Genius Siemens Genius
Siemens Genius
There are some other things you can do with the CTRL key in the displays which are listed in the Keyboard and Display Shortcuts Knowledge Base Article
Thank you very much again! That worked!
