Can't leave measure screen in LMS test.lab
When I go to the measure screen all of my navigation arrows go away and don't allow me to leave the measurement screen.  Any ideas ??
Re: Can't leave measure screen in LMS test.lab
Siemens Genius Siemens Genius
Siemens Genius
Screen resolution needs to be at least 1024 in vertical direction to see the LMS Test.Lab Navigation toolbars.
You can use CTRL-PAGEUP and CTRL-PAGEDOWN to move between tabs when you cannot see them:
https://community.plm.automation.siemens.com/t5/Testing-Knowledge-Base/CTRL-PageUp-or-CTRL-PageDown-...
Did your screen resolution change recently?
Yes got a new lap top
Siemens Genius
You may want to check the screen resolution on the new laptop.
Right click in the background and select "Screen resolution".
screen.pngChoose any resolution where the last number is bigger than 1024:
minimum.pngPress Apply when finished.
Good luck!
