Canbus file in SmartScope
I have a DBC file I want to use in SmartScope.  At the top of the CAN setup menu, there is a "Open Database".  How do I get my DBC file selected there?
Re: Canbus file in SmartScope
Plug your Tablet into the USB of your computer.  You will get a message about being able to view the contents of the tablet. Allow this.
Then thru Microsoft Windows, navigate to the following directory and store the DBC file in it:
[computer name]\Xperia Z3 Tablet Compact\Internal storage\DCIM\Siemens\Dbc
This directory could be a little different depending on the tablet you use.
Also make sure to turn on the 'CAN Visualization' for the desire channels in the CAN setup.  More details here:
https://community.plm.automation.siemens.com/t5/Testing-Forum/Can-t-view-Canbus-channels-in-LMS-Smar...
That worked! Thanks!
