Re: Changing parameters value in LMS.TestLab by Automation (VB)
Thanks for the file! Unfortunately, according to what was said by PMoore, to automate a wide process I should constantly receive support and this is not possible for me. It is very frustrating! I was hoping for a more exhaustive manual, but I realized it was not available.
After that, I chose to export data from Test.Lab using Matlab but I encountered other problems. Matlab 32-bit is essential for LMSTestLabAutomation, but its last 32-bit version is R2015. Furthermore, after the server COM creation, when I use the function "invoke" to invoke an interface (for example, IDatabase), I get an error. How can I solve the problem? How can I use the interfaces (IDatabase, IDataWatch etc..) in Matlab (32-bit version)?
Would it be possible to have indications about the COM object interfaces in MATLAB? I can not use them. Thanks in advance!
