Have the LMS Test.Lab run name always be in display?
Is there a way to make it so the run name always appears in the legend by default in displays?
Every time I open a new display, I always have to right click on the legend, choose Options, the Custom Content, Origin/Test.Lab, Type/Run, and put the Name field from Available to Selected.
Re: Have the LMS Test.Lab run name always be in display?
Dear Merric,
You can open a blank frontback and Save as layout the edited display.
If you use the same display again the run name will be available in the legend:
1 - Open a blank frontback display
2 - Right click in the box of the legend and select Options
3 - Select the run/name to be available on display
4 - Save this edited display as layout with the Frontback original name or with a new name
5 - If you saved with original frontback name will you can open the frontback and it will be with run name. If you use a new name you can enter in create a picture and choose the edited display.
Also you can do this in Layout management, faq available in solution center:
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=layout+management&dt=...
In our knowledge base there is a similar material showing more options:
https://community.plm.automation.siemens.com/t5/Testing-Knowledge-Base/LMS-Test-Lab-Display-Layouts/...
Regrds,
Emerson Umbinger
Much better! Thanks
