cancel
Hidden entries in TecWare Falancs toolbar
Dear all,
I am having a trouble with LMS TecWare Falancs v3.10.Some entries in menu toolbar are hidden,for example "FE result files","set files","load cases" and some items in tool menu.
Please see the attached pictures.
Since I haven't modified any parameter after installation,I don't know what could be the solution.
Thanks very much in advance for any suggestion,
Alessandro.
Re: Hidden entries in TecWare Falancs toolbar
Any answer?
The last release of LMS Tecware/FALANCS that supported the FE related features was LMS Tecware 3.8. After that, we discontinued LMS FALANCS FEM inside LMS Tecware. It was replaced by LMS Virtual.Lab Durability.
So, please install LMS Tecware 3.8 and you will see the menus again.
By the way: it is no problem to install LMS Tecware 3.8 and 3.10 in parallel and use both. You just have to make sure you have installed both FLEXlm and RLM licenses.
Best regards
Holger
Thank you Mr. HolgerZeinert.
Since I don't think it is possible to have LMS Tecware 3.8 in my University computer,I should solve the issue using the latest version of LMS Virtual.Lab Durability or I must use the old TecWare version?
Thanks in advance,Alessandro.
That depends what you want to do. If you have access to LMS Virtual.Lab Durability, then use this installation.
If you specifically need to process your data in LMS FALANCS, you'll need to install LMS Tecware 3.8 in parallel.
Hope this helps.
Holger
I need to perform a fatigue life analysis in Falancs using results from .op2 MSC Nastran output,data sets from FE model and S-N curve in a created database.
Is this the right way or I should ask my tutor for LMS Virtual.Lab Durability?
Thanks,Alessandro.
Your use case should work fine in LMS Virtual.Lab Durability. Please ask your tutor whether you can have access to it.
Best regards
Holger
Thanks,could I ask you the last question? Considering that I should use FE
results and data set,your suggestion is valid for all Virtual Lab versions
or I need to install the old one? We should have installed the v13.4 only.
Alessandro.
LMS Virtual.Lab Durability v13.4 is perfectly fine.
Ok.Thank you very much for support.
Best regards,Alessandro.
