Instantaneous versus monitor folders in LMS Test.Lab Signature?
What is the difference between the Instantaneous versus the Monitor folder under "Data Explore" in the LMS Test.Lab Signature Measure worksheet?  Why would I use one or the other?
Re: Instantaneous versus monitor folders in LMS Test.Lab Signature?
Siemens Legend Siemens Legend
Siemens Legend
Monitor: allows you to display in real time the frequency spectrum, scrolling time history and
time block of dynamic channels and the instantaneous value of tacho and static channels.
Instantaneous: this makes it possible to visualize the single spectra of the waterfall data in a
2D display window (such as an Upper/Lower or a FrontBack display).
If you want to visualize the data in real time, that's possible in the monitoring folder.
Here's the link to a FAQ at GTAC: https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=online+monitoring&pd=...
to further explain.
Hong
