LMS Test.Lab: Can't Calibrate - Channel Status Not Active
Have a test with 3 microphones and 9 vibration channels.
When I go to calibration, I cannot select my microphone channels for calibration.  The channel status field says "Not Active", even for my vibration channels.
Here is a screenshot of what I am seeing:
Re: LMS Test.Lab: Can't Calibrate - Channel Status Not Active
You might try selecting Pa for the units at the top of the dialog.
Selecting Pa up above worked.  Guess it is good not to calibrate a microphone with g's.
 Pressing "Check" and then "Start" also helped.
