LMS Test.Lab Modal Analysis: Correlation Percentage Table?
Back in Cada-x, when I did FRF synthesis, each FRF has a error and correlation percentage.  I used to be able to put these into a single table which showed DOF, Correlation %, Error %.
Is there a way to do this in LMS Test.Lab Modal Analysis?
To be clear, I know how to get the correlation and error percentage in Modal Synthesis in LMS Test.Lab.  Just don't know how to get a table.
Re: LMS Test.Lab Modal Analysis: Correlation Percentage Table?
Siemens Legend Siemens Legend
Siemens Legend
You can go to Modal Synthesis workbook, then follow the picture below:
1st click Parameters... -> then check Generate correlation-error list option  -> highlight the row as showing on step 3 -> then click the down arrow button as shown in step 4
Once it's completed, you'll see a table geneated:
Then you can highlight all rows and column, right click copy then paste in excel.  If you click Close, the table will close and it's not saved any where in the project; then you'll have follow the steps from above to regenerate the table again.
Good Luck!
Hong
That is perfect!  This Test.Lab stuff is really growing on an old Cada-x guy like me.
