LMS Test.Lab: Title on plot?
How do you put a title on a graph in LMS Test.Lab?
Re: LMS Test.Lab: Title on plot?
Dear Gizma.
It is simple. Check the pdf file attached.
It is the simplest way to do. Let me know if  the answer met your expectations.
Emerson
Gizma,
Here is another helpful title tip.  While holding down the control key, click on the graph edge and drag.  You can resize the graph.
 The title can be put outside of the graph this way.
 Click on the top edge of the title box to move it.
 Hope that helps some more.
