Order cursor in colormap versus time?
My order cursor menu is insensitive.  I think it is because I have a colormap that is processed against time, but I would still like to see my orders on the colormap anyway.
Is there anyway to put an order line in this colormap?
Re: Order cursor won't work in colormap versus time?
 No problem!  If you have calculated some orders for the same waterfall, just drag and drop them into the lower left corner of the colormap display to see them.
This requires order sections.  If you do not have any orders, you will need to reprocess your data and calculate them.
That did the trick!
