Question about lms software: Octave data from impact measurements?
Any idea how to get octave data (for example octave 1/3, 1/6, 1/12 etc.)  from tested hammer impact data? Doing an impact measurement with an acoustic response.
Re: Question about lms software: Octave data from impact measurements?
There are two ways:
1)  Display the narrow band data in an octave display and it will be converted.  You can right click on the X axis to change the format to a different octave format.
2)  Use the Data Calculator to convert to octave with the Octave command.
Impact measurement data, like an FRF, can be displayed in Octave format as follows:
1. Open an “Octave Display”
2. Drag and drop an impact measurement into the display:
3. Right click on the X axis to change Octave formats
Hope that helps!
