Run TecWare with LMS Test.Lab tokens?
I want to do some fatigue life calculations, and was told that TecWare can do this, and can even be run with my LMS Test.Lab tokens in the latest versions.  Only one problem, after upgrading to revision 17, how do I start TecWare?
Re: Run TecWare with LMS Test.Lab tokens?
Siemens Legend Siemens Legend
Siemens Legend
Icons to start Tecware can be created by running from Windows: "Start -> All Programs -> LMS Test.Lab 17 -> Tools -> Add LMSTecWare shortcuts".
You can run the process builder to calculate damage and fatigue life:  https://community.plm.automation.siemens.com/t5/Testing-Knowledge-Base/Calculating-damage-in-LMS-Tec...
