Setup from TEDS sensors
In chanel setup what is Setup from TEDS sensors ?
Re: Setup from TEDS sensors
Dear Chirag.
Transducer Electronic Data Sheet (TEDS) is a technology that enable the manufacturer store data in the memory of the sensor.
The sensors with this technology has embedded some informations about your sensor like: serial number, sensitivity, type and calibration date.
You can work insert your sensitivity in your channel set up. Check the steps below:
1 - With the sensor conected in your hardware, go to the channel set up>Read Teds and press Refresh. The channels with TEDS sensor will be updated.
2 - Press Insert
3 - Note that the data of the sensor will be in your channel set up.
Emerson Umbinger
Thanks for the reply.
