09-01-2017 05:19 AM
09-01-2017 07:54 AM - edited 09-01-2017 08:31 AM
Dear Chirag.
Transducer Electronic Data Sheet (TEDS) is a technology that enable the manufacturer store data in the memory of the sensor.
The sensors with this technology has embedded some informations about your sensor like: serial number, sensitivity, type and calibration date.
You can work insert your sensitivity in your channel set up. Check the steps below:
1 - With the sensor conected in your hardware, go to the channel set up>Read Teds and press Refresh. The channels with TEDS sensor will be updated.
2 - Press Insert
3 - Note that the data of the sensor will be in your channel set up.
Emerson Umbinger
09-02-2017 12:33 AM
Thanks for the reply.
