Spectral Acquisition - Measure
How to enable Online Data Visualization?
Re: Spectral Acquisition - Measure
On the Test Setup worksheet you can select to measure and save Time blocks, Octaves, Spectrums, etc.  If you select either Measure or Save you can view that function ont eh Measure worksheet.  You can have up to six displays in the Fixed Layout select the functions to view via the pull downs in each display and then use the arrows to scroll through your channels.
You can also switch from the Fixed Layout to the User Defined Layout if you want to use more than six displays or you want more than one channel in each display.
