Split an ICP accelerometer?
Can I split an ICP accelemeter into two different acquisition systems and record the data?  For example, I want to record both with my Scadas and another data acquisition system.
Re: Split an ICP accelerometer?
We've tested this in the past on two Scadas systems and it worked provided only one system was set to ICP and the other set to Voltage AC.
To verify it, I would suggest using a calibrator on both systems and calibrate the channel in both to make sure the sensitvity is what you expect.
