Tracking Settings - Time data processing
Hello sir;
I would like to know how "use Tracking Settings and trigger settings" in the Aquisition parameters of the Time Data Processing work sheet work. How to use please explain about.
Re: Tracking Settings - Time data processing
See this community article in the Testing Knowledge Base:  https://community.plm.automation.siemens.com/t5/Testing-Knowledge-Base/LMS-Test-Lab-Throughput-Proce...
In a nut shell, setting measurement mode to Stationary will provide an averaged 2D function and setting it to Tracked will provide a 3D waterfall or colormap which can be tracked against Time, Tacho, any Static channel, an Event based on any channel or Free Run (with each spectrum measured according to the frame size = 1/(frequency resolution)).
