Tyre experimental modal analysis
I am planning set up experimental modal analysis for tyre of range from (0.5 meter to 2.5 meter radius)
I also planned to correlate with simulation results(FRF, Model shapes and modal frequencies).
What is the hardware required for the above mentioned.
If you need more details I can explain.
Kesava Reddy K
Re: Tyre experimental modal analysis
I think you should need a hammer or a shaker and some acceleration transducer.
