Vibration Dose Value : VDV
How to calcaulate Vibration Dose Value (VDV) of seat track vibration time signal (measured in m/s^2) using LMS Test Lab.VDV.PNG
  http://www.acoustic-glossary.co.uk/vibration-dose.htm
Re: Vibration Dose Value : VDV
Siemens Legend Siemens Legend
Siemens Legend
First you'll need to go to Tools->Add in to select Human Body Vibration add in; once you have the add in please follow steps below:
Picture2.jpgHong
You can calculate VDV with the following steps.
Under “Tools -> Add-ins” turn on “Human Body Vibration” (and Signature Throughput Processing if not already on).
In Signature Throughput processing, choose “Change Settings” under “Section”.
Go to the tab called “Level Calculation”.  There is a toggle at the top, select “VDV – Vibration Dose Value” and press “Add”.  Then “Close” the menu.
You can now calculate VDV!
