WF_math advanced command
Hello
When trying to work with waterfalls and VBA, I 've seen this:
WF_math in advanced command
Is this command available ? if yes how to use it?
because no information available about the "operation" item
Re: WF_math advanced command
Siemens Legend Siemens Legend
Siemens Legend
Dear,
WF_Math is available in the ICmdAdvanced. But, depending on your Test.Lab  version it's visible or not.
In code snippet in attach, you can find the syntax and also a work-arround in case.
Also in this document we explain the value "Operation".
Kind regards,
I have try it with Test-Lab 16 and VBA. Butnot working.
The WF_math function return "Mismatch' error (Perhaps Operation item has to be an Object instead of only integer?) .
The workaround solution returns a waterfall where all blocks have 0 line length.
