Waterfall bind strategy Embedded - Semi-Embedded
I've done some measurements (Testlab 14) with the waterfall bind strategy set to Embedded. Is there any way to change this data to Semi-Embedded without processing it again so that I can reduce the project file size?
Thank you.
Mircea Rosu
Re: Waterfall bind strategy Embedded - Semi-Embedded
Unfortunately, no.  You'd have to:
1)  Change to semi-embedded waterfall bind strategy
2)  Re-process
3)  Delete original waterfalls
4)  Use Save As... to a new project or the original project and turn on the compress project option.
Thank you very much Kevin.
Best regards,
Mircea
