Wave file export from LMS Testlab Sound Diagnosis
I have been using LMS Test.Lab Sound Diagnosis using this article: https://community.plm.automation.siemens.com/t5/Testing-Knowledge-Base/LMS-Test-Lab-Sound-Diagnosis/...
The filters have been very helpful in isolating unwanted noises.
For a presentation, I want to make wave files of the sounds with the filters applied.  How do I do this?
Re: Wave file export from LMS Testlab Sound Diagnosis
HI Gizma,
Since you filtered the sounds and save you sound diagnosis the data will be available in your project.
Afther this you can do a right click and select Export to> wav at Navigator worksheet.
If you need more details there is an faq in GTAC about it:
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&p=1&q=export+wav&file_t...
Emerson Umbinger
