Why i can not access the Solution Center?
When i try to access the Solution Center, the website tell the that the resource is forbidden. But i can access there a few days ago.
Re: Why i can not access the Solution Center?
Hello Jeff,
If you reach out to your local support team via phone or email with either your email or the webkey you were using, they can check the status of your webkey account.
Kevin
