Wirelessly transfer data from ScadasXS to PC?
Is there a way to transfer files wirelessly from the ScadasXS to my PC?  After I take data with SmartScope, I usually transfer the data by moving the microSD card.
The XS has wifi built into it, so I was wondering.
Re: Wirelessly transfer data from ScadasXS to PC?
Dear Fred,
There 2 options to import a data without remove the SD Card.
1 -  Using USB cable by FTP
2 - Using Wifi connection by FTP
Below a faq935 in our Solution Center that show the options.
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&dt=faq&q=lms-scadas-xs&...
Also you can find this faq in Test.lab 17 documentation:
C:\Program Files (x86)\LMS\LMS Test.Lab 17\central\Help\FAQ
or searching in the Search app in the installation, example in the post:
https://community.plm.automation.siemens.com/t5/Testing-Forum/Cool-search-tool-in-Test-Lab-17/m-p/49...
Emerson
Hi Emerson,
faq935 is a pretty cool faq!
I did not know that you could map a wireless ftp to a network location:
I did it and can access the files and templates, and just drag and drop them onto my PC, no physical connection!
