"Turbine Test Recording Mnager" Module
Good morning.
I've entered to "Turbine Test Recording Mnager" Module andd I can't access to "Help". I'd like to have more information about this module. Here I show the picture:
Thanks in advance
Alvaro
Re: Torsional Vibration: What is it?
Just curious what is your application?
This is a module designed for high throughput long duration recording.  I am not sure why there is no help file.  I can check if intersted.
Well the version of the application is Test.Lab 17
If you have a help file, would be a good help to introduce more into this module.
Thanks for advance
Alvaro
Hello Alvaro,
I'm surprised you can enter that product.  If you purchased it, I assume training or installation was done by your local support team as it's fairly complicated to setup.   It was developed for a very specific niche application.  Are you using a training license or an evaluation license?
As John stated, it's a product that supports high throughput, long duration acquisition across multiple networked computers and multiple Scadas systems combined in a Master / Master configuration.
Kevin
