Access to different data file formats using LMS Tecware
For analysis software it is a strong feature to be able to read and write many different formats. The time data formats that can be accessed in LMS Tecware are listed below:
Format
Access
LMS ASCII
r/w
LMS Tecware IF/Labsite
r/w
LMS Test.Lab/CADA-X (TDF)
r/w
LMS Pimento/Roadrunner (SKALAR20-TDF)
r
LMS Data Streaming Format (LDSF)
r/w
LMS Recorder File (TRP, XTRP)
r
LMS Test.Xpress (XDF)
r
Aditec EDT
r
Aditec PBK/PK2
r
ASCII
r
ETAS INCA MDF 3
r
HBM catman bin
r
HBM MGCplus mea
r
HEAD acoustics
r/w
I-DEAS BUFF (binary universal file)
r
imc FAMOS RAW/DAT
r
IST RigSys
r/w
Kyowa KS2
r
LEXADE
r/w
MATLAB
r
MDF 3, 4
r
MH E.D.A.S.
r
MH EdasWin
r
MOOG fstrm
r/w
MTS RPC-III (integer and float)
r/w
nCode DAC
r/w
NI DIAdem DAT
r/w
NI DIAdem TDM/TDMS 1.0/2.0
r/w
SOMAT SIF/SIE (multiple runs supported)
r
TEAC Data Acquisition File Format (TAFFmat)
r
Tokyo Sokki TMR Recorder
r
In Tecware, you can either use "Import Files" or "Insert files" to load data.
The Import is automatically detecting the format based on file name extension and file header. In most cases ,the format can be derived from the file without problem:
The Insert Files command allows to specify the format of the file:
Once loaded, LMS Tecware will know how to read that file and throughout the software all files can be used in the same way.
Contributors
