CTRL-PageUp or CTRL-PageDown to move between Worksheets in Simcenter Testlab
Want to move between Simcenter Testlab Worksheets without a mouse?
On your keyboard, press CTRL-PageUp or CTRL-PageDown to move between Simcenter Testlab (formerly called LMS Test.Lab) worksheets.
CTRLkey.pngJump between “Channel Setup” worksheet and “Calibration” worksheet with a CTRL-PageUp keystroke combination.Also use CTRL-Home and CTRL-End to jump to first and last worksheets.
This tip can be very useful when using a screen with less than the recommended screen resolution.  On the lower resolution screens, worksheets tabs can sometimes disappear.  Using the keystroke combinations, you can still navigate your worksheets despite not being able to view them on the screen!
Questions?  Email peter.schaldenbrand@siemens.com or contact Siemens PLM GTAC support.
Simcenter Testlab Tips:
