Insert statistical metadata in ProcessBuilder's channel/file math
Siemens Visionary Siemens Visionary
Siemens Visionary
Question
How can I add statistical metadata into the file/channel math's formula in the ProcessBuilder?
Answer
You perform a right-click within the Formula section.
And select Formula Editor.
Within the new window you select: Insert Attributes
You will now get a more detailed view:
So you first select “Statistics” as Category.
Then you select the statistical value you want to insert.
And afterwards you click on “Insert reference” and then the correct term for e.g. the maximum of the first file will be inserted as:
$(Maximum:InputObject[1].Statistic.TS.Max)
Then you apply the new formula and it should work like intended.
This specific formula in a file math method will look like this:
"({File1}-{File2})/" & InputObject[1].Statistic.TS.Max
Contributors
