LMS Test.Lab Displays: Keyboard and Mouse Shortcuts
Siemens Genius Siemens Genius
Siemens Genius
(view in My Videos)
There are some nice tricks to navigating data displays in LMS Test.Lab, some in combination with the mouse, others using only the keyboard.
One of the "greatest of all time" keyboard shortcuts is to hold down the CTRL key when right clicking in a display.  By doing this, the main display menu with Single X Cursor, Double X Cursor, Harmonic Cursors, etc will always appear, regardless of where the right click is done in the display.
Here is a list of other shortcuts:
Shortcut Key
Action
For which display
Mouse
Drag horizontally
zoom in x-direction
all function displays
Drag vertically
zoom in Y-direction
Drag diagonally
zoom in XY-direction
Shift-drag horizontally
pan in x-direction
Shift-drag vertically
pan in Y-direction
Shift-drag on overview
pan over x-axis
upper/lower - overview
Shift-click on overview
pan over x-axis - shifts 1 range forward or backward
Shift-scrollwheel on axis
scroll over axis
Ctrl-scrollwheel on axis
zoom in/out on axis
Ctrl-drag on axis
move axis position
Ctrl-drag on splitter between upper and lower of a BODE
move splitter
Bode + Upper/Lower with 2 views
Ctrl-double click on Y-axis
expand axis
upper/lower (with more than 2 views)
Right-click on axis/curve/cursor/legend/empty space
axis/curve/cursor/legend/default popup menu
Scrollwheel
Panning up/down
Table
Shift-scrollwheel
Panning left/right
Table
Ctrl-scrollwheel
Zooming (font sizing)
Table
Ctrl-right click (anywhere)
default popup menu of the display
Double click on axis
"set fixed limits" menu comes up
Double click on curve
"adjust curve properties" menu comes up
Double click on cursor
"move to position" menu comes up
Keyboard
Backspace
UNDO last axis setting (up to 20)
all functions display
Cursor keys (no curves selected)
move selected cursor (normal interval)
Shift-cursor keys (no curves selected)
move selected cursor (small interval)
Cursor keys (with one or more curves selected)
move selected cursor to next/previous sample
Ctrl-cursor keys (with one or more curves selected)
move selected cursor to next/previous local maximum
X axes only
Shift-O keys (with the display selected)
Switch between Overlaid/Stacked mode
Upper/Lower + Multi-trace display
To get an up to date list of keyboard shortcuts for displays, right click on the display (while holding down the control key) and select "Mouse & Keyboard Tips".
There are also nice keyboard shortcuts for the measurement applications: different keyboard combinations can be used for arming, disarming, stopping a measurement.
Related Links:
LMS Test.Lab acquisition tips:
LMS Test.Lab Display Tips:
Contributors
