Simcenter SCADAS Hardware Cable Guide
Siemens Genius Siemens Genius
Siemens Genius
Need additional or replacement cables for your SCADAS Mobile, SCADAS Recorder, or SCADAS XS?
Use the tables below to determine the cable you need!
  • Cable Connector Types - Definition and pictures of cable connectors.
  • Cable List - List of SCADAS cables with part number, description, and picture.
  • Cables per SCADAS Card - List of cables per SCADAS card.
  • Cable Connector Part Numbers - For ordering direct from manufacturer.
Descriptions and pictures of connectors used on SCADAS cables.
Name Comment Photo
BNC Male
(BNC Plug)
Common cable-end connector, used with a vast majority of transducers and signal types.  Normally the connector to be plugged into a SCADAS module or adapter cable.
*1951 Patent, see this link: https://en.wikipedia.org/wiki/BNC_connector
BNC Female
(BNC Jack)
Common connector, use directly as a 'bulkhead' connector of some SCADAS modules, oftentimes the connector at the end of an adapter supplied with a frontend.  BNC-Jack-Female.jpg
SMB Male
(SMB Plug)
Connector type used in first-generation SCADAS Mobile systems and V8 input modules.  Male end was supplied with SMB-BNC adapter cables.  SMB-Plug-Male.jpg
SMB Female
(SMB Jack)
Connector type use in first-generation SCADAS Mobile systems and V8 input modules.  Female, or Jack, was a 'bulkhead' connector on frontend.  SMB-Jack-Female.jpg
LEMO 00 Male
(CAMAC Male)
Smallest LEMO connector used with SCADAS hardware, single-pin, no-keyed version supplied as part of the CAMAC-BNC adapter for V8-E cards or some source / output connections of certain XSI / SYSCON interface modules.
The same LEMO is also used with some keyed, 3-pin or 4-pin adapter cables, generally for SCADAS tachometer, source, or vibration control stop connectors.
LEMO OB, 1B, 1S
(LEMO Various)
Various size LEMO connectors, with varying internal number, arrangement, and gender of pins, depending on application, connection, and module type.  Different versions may or may not have one or two 'keys' for alignment, with different spacing as needed to avoid improper connections.
SMA Reverse Polarity Male
(SMA-RP Male)
Bluetooth, WiFi, and Pass-by Noise antennas use this connector type.  SMA-RP-Male.jpg
SMA Reverse Polarity Female
(SMA-RP Female)
SCADAS 'bulkhead' mating connector for Bluetooth, WiFi, and Pass-by Noise antennas.  SMA-RP-Female.jpg
List of SCADAS Cables
Product ID numbers (for ordering replacements), descriptions, and pictures of SCADAS cables:
  • Cable Part number is typically on a sticker wrapped around the cable.
  • If having trouble finding cable, try the next section which lists SCADAS cards and associated cables.
Product ID Price Book Description Layman's Terms Cable Part# Cable Picture
SCM-CAS06 SCM spare CAMAC-BNC adaptor for Tacho 4-pin CAMAC(LEMO) to (1) BNC 80200023  camac_to_bnc3.png
SCM-CAS07 SCM CAMAC to two BNC adaptor for DAC 4-pin CAMAC(LEMO) to (2) BNC 80200022  dual_tach_source.png
SCM-CN4 SCM CN4 DB9 A/B splitter cable (*Not module!) DB9 female plug to (2) DB9 male plugs 80200037  SCM-CN4.png
SCM-DPC05 SCM 2-m DC cable 1/2/3/5/6-slot frames 3-pin LEMO to DC (cigarette lighter) plug 80200501  car_power_supply.png
SCM-DPC09 SCM 2-m DC cable 7/8/9/10-slot frames 3-pin LEMO to ring terminals for battery 80200010  power_cable.png
SCX-CAS03 SCx spare LEMO to BNC adapter VB8 7-pin LEMO to BNC 80200605  lemo_bnc2.png
SCX-CAS04 SCx spare LEMO to pigtail adapter VB8 7-pin LEMO to bare wires 80200608  lemo_to_open_wire.png
SCX-CAS05 SCx spare CAMAC-BNC adaptor for Vx & DAC 1-pin CAMAC(LEMO) to BNC 80200021  camac_bnc.png
SCX-CAS08 SCx spare CAMAC-SubD adapter CAN ch 4-pin CAMAC(LEMO) to DB9 serial plug 80200030  canbus_9pin.png
SCX-CAS11 SCx spare LEMO-MIC to LEMO-MIC for VM8 7-pin LEMO Plug to 7-pin LEMO socket 80200607  mini_lemo_to_lemo.png
SCX-CAS12 SCx spare LEMO to BNC for VM8 7-pin LEMO to BNC 80200606  lemo_bnc.png
SCX-CAS14 SCADAS LEMO to 3 BNC connectors for XS and V24 9-pin LEMO to (3) BNC female 80200017  lemo_to_three_bnc.png
SCX-CAS15 LMS SCADAS 2m breakout cable for V24M HD SCSI to VHD SCSI
SCX-CAS17 SCx Satellite interface cable (5m) 8-pin to 8-pin ruggedized interconnect 80207105  satellite_cable.png
SCX-CAS18 SCX SATELLITE INTERFACE CABLE (15M) 8-pin to 8-pin ruggedized interconnect 80207115  satellite_cable.png
SCX-CAS20 CABLE for OBD-II and CAN-FLEXRAY DB9 serial socket to vehicle ODB-II plug Vector 22089  OBD.png
SCX-CAS22 SCADAS breakout box Remote On/Off 3-pin LEMO to 3-pin Socket / Terminals 80501020  scx-cas22.jpg
SCX-DSCU DAC-Shutdown Box cable (10m) (*Not button box!) 3-pin CAMAC(LEMO) to 3-pin LEMO 80209801  dcsu_cable.png
SCX-SIC37-1 SCx one m optical master/slave cable Fiber-optic master/slave cable, 1 meter 80206001  fiber_optic_between_frames.png
*10/50/Lg SCx 10-m (50-m) (Long) optical master/slave cable varying length of above cable 80206###  fiber_optic_between_frames.png
PCB Product LEMO-(3)BNC Adapter PCB version of XS / V24 LEMO-(3)BNC 010M137/000-04 PCB Lemo-3BNC.png
PCB Product LEMO-Triax Mini 8-36 4-pin PCB XS / V24 direct triax cable
034M59/M003
PCB Product LEMO-Triax Large ¼-28 4-pin PCB XS / V24 direct triax cable 010M136/M003  pcb_triax.png
PCB Product LEMO-DC Triax 9-pin PCB XS / V24 direct DC triax cable 037M29/M003  triax.png
Dytran Product LEMO-Triax Large ¼-28 4-pin Dytran XS / V24 direct triax cable 6784A30
Cables by SCADAS Data Acquisition Card
List of SCADAS cards and associated cables.
Photo of Card Card Name Cables Included Cable Replacement Options
 XSI - 785x120.jpg  XSI (1st Gen.)  (4) SMB to BNC cables
SCM-CAS01:
SMB to BNC (Set of 8)
XSI.jpg SCM
(1) FTP (LAN)
(2) Tacho / IRIG
(2) Source
(1) SCX-HIC-E2
(2) SCM-CAS06
(2) SCX-CAS05
CAMAC – BNC
SCR2
SCR2E
(1) FTP (LAN)
(2) Tacho / IRIG
(1) Source
(1) CAN
(1) GPS
(1) SCX-HIC-E2
(2) SCM-CAS06
(1) SCM-CAS07
(1) SCX-CAS08
(1) SCX-GNSS
SCM2
SCM2E
(1) FTP (LAN)
(2) Tacho / IRIG
(1) Source
(1) CAN
(1) SCX-HIC-E2
(2) SCM-CAS06
(1) SCM-CAS07
(1) SCX-CAS08
SCM2V
SCM2EV
(1) FTP (LAN)
(1) Stop Jumper (no wire)
(1) Tacho / IRIG
(1) SCX-HIC-E2
(1) SCM-CAS06
SCL220
SCL2E20
(1) FTP (LAN)
(2) Tacho / IRIG
(1) Source
(1) CAN
(1) SCX-HIC-E2
(2) SCM-CAS06
(1) SCM-CAS07
(1) SCX-CAS08
SCL220V
SCL2E20V
(1) FTP (LAN)
(1) Tacho / IRIG
 (1) SCX-HIC-E2
(1) SCM-CAS06
 AO16.jpg  AO16  Connecting cable to the connector box, and the connector block  Contact Siemens Office
 BDS4-E.jpg  BDS4-E  (4) LEMO Plugs (no wire) See Cable Connector Part Numbers below
 CIM2.jpg  CIM2
(2) LEMO-CAT(Ethernet)
Cable to Sony Camera
CN4
FR4
 (2) Sub-D Adapter Cables Contact Siemens Office
 DAC4.jpg DAC4 None
 DCH4-E.jpg DCH4-E (4) LEMO Plugs (no wire) See Cable Connector Part Numbers below
DB8-II
DB8III
DB8IIIC
SCX-CAS04:
LEMO - Pigtail (Set of 8)
SCX-CAS04:
SCX-CAS03:
LEMO - BNC (Set of 8)
DB8A
DB8B
DB8C
SCX-CAS04:
SCX-CAS04:
SCX-CAS03:
LEMO -BNC (Set of 8)
 ESO64.jpg ESO64 (2) FTP (LAN) (2) SCX-HIC-E2
 RV4.jpg RV4
(4) Tacho
(2) LEMO Plugs (no wire)
SCM-CAS06:
4-Pin LEMO to BNC (single cable)
 T8A.jpg T8A None
V24
V24-II
None
(8) LMS SCX-CAS14
Direct wire transducers
and/or adapters available
from PCB, Dytran, etc.
See table on last page
 V24M.jpg V24M
(1) SCX-BOB24 Breakout
box with 24 BNC’s
(1) SCX-CAS15 2m cable
to BOB24
(1) SCX-BOB24-RM2 19”
rackmount kit (optional)
 V4-E.jpg  V4-E  None
 V8.jpg  V8  8 SMB to BNC cables SCM-CAS01:
Alternative to
SCM-CAS01
www.cdint.com
 BFSB-174LN-1
Order individually
V8-E
V8-II
8 CAMAC – BNC cables (included)
SCX-CAS05:
CAMAC to BNC (Single cable, card requires 8 total)
 VS8-E.jpg VS8-E
1 Adapter for SPDIF (included)
SCX-CAS05:
Std. audio parts available from Radio Shack, etc.
Alternative to
SCX-CAS05
www.cdint.com
BFL00-174LN-1
Order individually
V8b-E
VS8b-E
None
VB8-II
VB8III-RT
(8) LEMO – Pigtail
(bare wire)
(8) LEMO – BNC
SCX-CAS04:
SCX-CAS03:
 VCF4.jpg VCF4
(4) CAMAC(LEMO) – BNC
SCX-CAS05:
No cable sold by LMS for charge, avail. from PCB (002B01), Dytran, etc.
VC8-E
VC8-ER
VC8-QS
None
 VD8-E.jpg  VD8-E  8 CAMAC(LEMO) – BNC
SCX-CAS05:
 VD8S-E.jpg VD8s-E Sub-D Mating Connector No part sold by Siemens; std. connector available online
 VD8B-E.jpg VD8b-E None
 VD8MO-E.jpg VD8MO-E 16 CAMAC(LEMO) – BNC
SCX-CAS05:
CAMAC to BNC (Single cable, card requires 16 total)
 VM8-E.jpg VM8-E
(8) LEMO – LEMO (mic.)
SCX-CAS11:
LEMO – LEMO (Single cable, card requires 8 total)
SCX-CAS12:
LEMO to BNC (Pack of 8 cables)
 WFI2.jpg WFI2
(2) CAMAC(LEMO) – BNC
Cable to Kistler Device
SCX-CAS05:
CAMAC to BNC (Single cable, card requires 2 total)
 SC-XS06-E.jpg SC-XS06-E
Same as XS12-A, but with LEMO - 3 BNC (2 cables included)
Same as XS12A, except:
SCX-CAS14:
LEMO - 3 BNC (Single cable, card requires 2 total)
 SC-XS12-A.jpg SC-XS12-A
(1) Hard case – XS+Tablet
(1) Soft bag
(1) Dual Tacho
(1) CAN LEMO–DB9
(1) USB Car DC Charger
(1) USB AC Wall Charger
(1) Micro USB–USB Cable
(1) SPDIF Head Adapter
(1) Sony 7” Tablet
(1) 32Gb Micro SD Card
(1) GPS
(4) LEMO – (3) BNC
(1) SCX-CASE04
(1) SCX-CASE06
(1) SC-XS-CAS03
(1) SCX-CAS08
(1) SC-XS-PA4
(1) SC-XS-PA8
(1) SC-XS-USB1m
(1) SC-XS-CAS02
(1) SCX-TAB
(1) SC-XS-SD32G
(1) SCX-GNSS
(4) SCX-CAS14
LEMO – (3) BNC (qty. 4)
 SC-XS12-N.jpg SC-XS12-N
Same as XS12-A, plus
(1) Mini I/O to CAT5e
Same as XS12A, plus:
(1) SC-XS-LAN2M
 SCX-SWITCH.png SCX-SWITCH
(1) Phoenix to LEMO cable
(1) Phoenix to DC car
lighter cable
(1) AC/DC power brick and
wall cord
None
 PCB or Dytran Products  LMS Specific Cables  Need (qty. 1) per ABC input on XS or V24
 SCX-CAS20.jpg SCX-CAS20 Not included with XS
SCX-CAS20:
ODB-II – DB9 (qty. 1)
 SCX-ABH04.jpg  SCX-ABH04  (1) Hard case for headset
(1) SCX-CASE04
 SCX-ABH04-C.jpg  SCX-ABH04-C  None
 SCX-ABH04-V.jpg  SCX-ABH04-V  None  Required to use ABH04 headset when recording with Scadas Mobile/Lab V8 input module
 SCX-ABH04-B.jpg  SCX-ABH04-B  None  Required to use ABH04 headset when recording with Scadas Mobile/Lab VB8 input module
 SCX-ABH04.png  SCX-ABH04-C2B  Sold in pairs, order (1) per SCX-ABH04-V  Required to use ‘V’ adapter with BNC input
Adapter to use
SCX-ABH04-V with V8 SMB inputs
 www.cdint.com  (2) L00FSB-174LN-1
List of  manufacturer model numbers for specific connectors.
Product Input and Example Plug Input Description Plug Description LEMO Part Number
SCX-V
 SCX-V.png Vibco SYSCON-II LEMO Stop Jumper Plug FGG.00.303.CLAD
VB / DB8  VB8 DB8.png Universal Input LEMO Plug (ea. channel) FGB.0B.307.CLAD
VM8  VM8.png Mic. / V / ICP Input LEMO Plug (ea. channel) FGG.0B.307.CLAD
Tacho / IRIG  Tacho IRIG.png SYSCON-II Tacho / IRIG Input LEMO Plug (2 per SYSCON, 4 per RV4) FGG.00.304.CLAD
Dual Source  Dual Source.png SYSCON-II Source LEMO Plug (1 per module) FGG.00.304.CLAD
IE  IE.png RV4 Input LEMO Plug (2 per module) FGG.1B.310.CLAD
V8 / VD8  V8 VD8.png V8/VD8/VS8 Input LEMO Plug (8 per module) FFA.00.250.CTAC
V24  V24.png V24 (3-ch.) Input LEMO Plug (8 per module) FGG.0B.309.CLAD
BDS4-E  BDS4E.png BDS4 Input LEMO Plug (4 per module) FFA.1S.306.CLAC
DCH4-E  DCH4E.png DCH4 Input LEMO Plug (4 per module) FGG.1B.302.CLAD
GPS  GPS.png SYSCON-II GPS 3v Antenna w/ MCX Plug www.4starelectronics.com
CANBUS CANBUS.png  SYSCON-II CAN LEMO Plug (1 per module) FGG.00.304.CLAD
Power  Power.png SCM/R Power Supply LEMO Plug (1 per frame) FGG.1B.303.CLAD62Z
SCX-CAS22  scx-cas22.jpg SCR2E0x Remote On/Off Breakout Box
Screw Terminals for connection of power leads that will automatically turn on / off SCADAS Recorder
FGG.1B.303.CLAD62Z
 Questions?  Email jason.wayman@siemens.com or contact Siemens PLM GTAC Support.
*** All information provided in this document is subject to change at the discretion of Siemens PLM ***
SCADAS Acquisition Hardware links:
Simcenter Data Acquisition links:
Simcenter CAN Bus Acquisition links:
Comments
Hello Jason!
Could you give more details about application of cable SCM-CAS07?
I have this cable but normally I use only one input (this cable has 2 inputs).
Hello
To use the SCM-CAS07 to output signals from the software, do the following.
1.  In Spectral or Signature acquisition, select "Tools -> Add-ins" and turn on "Source Control".
2.  In the Scope worksheet (for Spectral) or Acquisition Setup worksheet (for Signature), the sources can be turned on, and the type of signal output selected. This will be on the right side of the screen.
Use the Start Source and Stop Source buttons to turn the sources on and off.
Thanks!
I didnt know this Hardware function.
